I have used this site for advice on my 1988 Cherokee and wanted to post something that may be useful to someone. I recently replaced my freeze plugs on the side of the block and back of the head. They were extremely difficult to get in (incredibly tight) but finally got them driven in. I certainly didn’t drive them in correctly, as in didn’t use the right tool, but regardless, got them in. They looked great. Got everything back together and it started right up. Had an unrelated fuel leak so turned it off immediately. Looked underneath and sure enough had a freeze plug or two seeping…..very frustrating. Once I got the fuel leak taken care of and after sitting for a few days, started it again and let it come up to temperature. So far no more leaks or seeping around the freeze plugs. Just wanted to post this in case anyone else runs into the same issue upon installing new ones. My experience was give it a little time, and there’s a good chance they will seal themselves. It may be the heat or enough surface corrosion had to develop, but they are now not leaking.
