XJMarty
- Czech Republic
Let me preface this by saying that one advantage of buying a new vehicle is that you can stay on top of maintenance and repairs. One disadvantage of buying a used and neglected vehicle is the plethora of minor/major problems that can oftentimes be inherited, which can be a little overwhelming. Our XJ is no exception; it has a lot of repairs that need to be made. And since the Jeep is our daily driver and weekend workhorse, I’ve been trying to avoid too much downtime. In other words, I’ve only been addressing these “minor” problems once they’ve turned into critical problems.
With that being said, the underside of the Jeep is coated with oils from several leak sources. The leaks have certainly become an issue, especially for someone who’s a little OCD. Now that winter is here, this is a good time to start tackling some of these leak problems. Here’s a list of items that we found leaking!
Valve cover gasket
Oil Pan Gasket
Rear Main Seal
Front crank shaft seal
Transmission Pan Gasket
Transmission Cooler Line
Oil Filter Adapter
Power Steering Pump
Thermostat gasket
After evaluating what needs to be done, and knowing that one leak is no better than the other, we're going to start on top of the engine (valve cover gasket) and work down.
I’m not sure how much the aluminum valve cover with cooling fins will dissipate engine heat, but I thought this would be a good time to add one! I also like that it brings some color to the engine compartment. Included is the mounting hardware, gasket, and oil cap.
Crown Aluminum Valve Cover
Part # 3020323ALR
how is your valve cover holding?
Mine has baeen leaking around the vents and around the plug ever since
