So pretty much just wanted to say hey all, just registered here and look foward to being active on here.
That being said, i've used the search function and to prove it here are the two threads i've found on this topic which didn't quite conclude my issue.
http://www.naxja.org/forum/showthread.php?t=1017553&highlight=axle
http://www.naxja.org/forum/showthread.php?t=953251&highlight=axle
My question here is if i were to go rattle can, which is best fit to do the job on the axles and also the coils. I'm guessing i shouldn't use the same paint on both because the coils will flex and chip quickly? -- or -- raise the budget and not rattle can it (Some suggest POR/Epoxy)?
Axles If i were to rattle can, most either say Rustoleum Hammered or Protective Enamel.
Coils Really don't have the slightest clue which paint would be best suited here. Otherwise I'd use same paint but only leave a thin coat.
Thanks
Thanks
