Dingo509
- Yakima, WA
Re: overheating (Kinda long) FIXED
okay final plan of attack included a new Visteon aluminum core radiator with a single 1 3/8" tube, a 14" zirgo fan, the stock 93+ electric, bypassing the trans cooler in the rad, and removed the AC condensor. While i had the fenders off i installed the heat exchanger for the onboard shower, the coolant circulates through this full time and it added about a gallon to the cooling system. look for a write up soon.
The XJ never got over 210 the whole weekend of the NW fest. In town, stop and go it was well below 190, on the freeway it approached 210 very quickly but did not go over, and the major problem i WAS having was pulling hills. the entire 30 min climb to the trailhead it never got over 210. This leads me to believe the whole problem was initially caused by the GDI 3-core creating a restriction in the system.
As far as having to remove the fan pulley to install a zirgo electric fan, not so. IF you want to move the top of the radiator forward about an inch. I will have pics up soon on this too.
Thank you to all involved in helping me diagnois and fix this problem that has been annoying me for over 3 years. This is the reason
is the best.
Dingo
Dingo
