Dingo509
- Yakima, WA
ok installed the map adjuster, and removed the vacuum line going to the fuel pressure regulator, yes i capped the vacuum port. i also found the stock injectors and swapped them back in. i then set the map adjuster to 5.3 volts with the fuel pressure at 40 psi (autometer procomp mechanical guage). trying to get it to run rich. i didn't change anything it still gets just as hot just as fast.
so 2 more ideas. what should the fuel pressure be without the regulator hooked up?
and (long shot) but if i understand the map sensor adjuster correctly it only works in open loop operation correct? If the computer operates in closed loop operation then the adjuster does basically nothing. so could you use the same basic concept (and maybe parts) the build and o2 sensor adjuster? i think the o2 sensor only gets 1 volt instead of 5 but if you could change parts a little you should, in theory, be able to adjust the o2 sensor voltage so it will lean or richen the mixture in closed loop mode.
I think.
Dingo
I think.
Dingo
