Dingo509
- Yakima, WA
Ed A. Stevens said:Is the new aftermarket water pump the correct (reverse) rotation?
Is the volume of water bypassing the radiator through the heater valve excessive (do you have a flow restrictor in the valve or heater core bypass hose)?
Is the air dam and shroud under the radiator support in place?
The water pump is correct rotation i verified with a buddy's 95 since he had his water pump out at the same time. the new is an airtex btw.
I don't know if there is a restrictor in the heater circuit or not. all four hoses and the valve are new mopar parts.
The air dam and shroud under the radiator where removed probably 6 yrs ago. about 3 years before the problem started.
dingo
