Dingo509
- Yakima, WA
Before i get yelled at for this let me give you a history:
91 XJ 4dr. 233K 4.0 aw4 with a/c
In order of install per item
2 Radiators a stock 2 core and currently a gdi 3 core
3 water pumps 1 mopar, 1 cheap rebuilt, currently new aftermarket
6 thermostats mopar, 4 aftermarket 2@180, 2@ 195, currently mopar
2 heater valves, both mopar
2 t-stat housings both mopar, currently hand ported
all hoses have replaced at least twice
Fan setup went from stock electric and mechanical to dual electric (1 stock 1 flex-a-lite 110) to dual flex-a-lite 110
Other mods 99+ intake swap, 60mm throttle body, donaldson airbox rated at 350 cfm, 98 5.2L durango injectors
I have pulled the head and it checked and machined flat (.007 max is .006)
I can drive it just fine if the temperature is below 60 otherwise it overheats
Mainly on the freeway, i can sit idle in traffic at over 100 ambient and it runs below 200 all day. it also overheats very fast when pulling steep grades, at any speed or ambient temperature.
Ive been fighting this for 3 yrs. now and basically can't drive it in the summer.
Any ideas?
Dingo
Any ideas?
Dingo
