OME mod questions
Boatwrench
Petaluma, CA
2000 XJ, stock 4.0 w/ auto trans.
Picked up used OME 2.5 springs a couple of weeks ago, also purchased a new OME steering stabilizer and have four OME shocks on order.
A few questions.
1. Will installing the 2.5" springs require changing the trac-bar up front?
SYE, from searching this forum it looks like I'll need one, money's tight with the kids in school so.......
2. Can I get by with removing the rear drive shaft and just using the front to get me to Moab and back? about 3,000 miles round trip. -or- is operating a 'front wheel drive' XJ at 70-75mph across Nevada not such a good idea?
3. What other recommendations can you offer to what else needs to be done? remove rear sway bar? front dis-connects?
Thanks,
Tom
i have the OME and a Daystar kit on my 98 very little vibes and the trackbar is ok.
A few questions.
Thanks,
Tom
The OME will end up at around 1.75" - 2" of lift.
1. Not a requirment, but a recommendation.
2.I wouldn't. Throw on a T-case lowering kit for now.
3. Scrap the rear sway bar. If the money's tight, check on off-road.com in the Cherokee section. There is an article somewhere around there about home-brew disco's.
Flowers
My opinions:
1) 2" of lift will shift the front axle less than 1/2", which is barely noticable. I would not bother with an adjustable track bar until you go higher (and you will).
2) I would not worry about an SYE until you install the lift and make sure you have vibes first. If you do get some light vibes (you'll feel it at 30-35 MPH) then i would start with a small transfer case drop (1/2" shoud be fine). You can worry about the SYE later. Do not drive the vehicle without a rear driveshaft. You will stretch the chain in the transfer case. You should only drive on the front driveshaft in emergency situations.
3) Remove the rear sway bar and install a set of JKS discos. They are about $120 from DPG Offroad.
930 or 934 coils and JC1A or JC1b's?
I ran the 930's and a spacer and the JC1A with the MJ shacle with no vibes (ran a 2° shim)...
I'd agree with Flowers though, have a Tcase drop ready if it's bothersome.
Enjoy the ride!
