In that case it is either blow by, and / OR a blocked CCV line or CCV orifice in the rear valve cover to intake manifold line, the small line on older jeeps, just the orifice on newer jeeps. That line draws out the normal blow by air into the intake. If clogged, the blowby takes an alternate route out the crank seals and into the air filter box.
That also may be where some of the oil is going, the air filter box...
If you pull the valve cover and take an inch off the tube bottoms that drop down inside the cover (poor design aids in blowing oil out by burying the tube in oil), and remove the tubes and clean out the valve area, then reinstall them, that might need doing too! If you have a stuck piston ring issue, MMO, Marvel Mystery Oil is a great, safe, way to loosen them up.
There are some photo mod threads in older posts on
about the valve cover tubes inside the VC!!
Oil in the filter is a common problem caused by a clogged CCV line, orifice, and the defective OEM design of the tubes inside the valve cover (they are too long).
The orifice is sized to maintain the proper idle speed air flow bypassing the throttle body, and to suck out the blow by gases.
