Stiff shifting plus coolant leak?
illidurit
CA
97 XJ Country, automatic, 160K miles, trying to get to the bottom of a problem. The other day I drove away from my house in the morning, and I noticed immediately something felt weird.
On acceleration it didn't really want to shift, felt kinda like it was stuck in 2nd or something. Deceleration felt similar -- like when I got up to speed and then laid off the gas to coast, it didn't want to slow down. After 5 min on the highway I got smoke from under the hood and the engine died when I pulled over to stop. I discovered a big leak from the lower radiator hose next to the water pump, and what was left of the coolant in the reservoir was smoking. The temp gauge never showed overheating, there was no smoke out the tailpipe, and the dipstick had clear oil (to me this should rule out head gasket).
I replaced the radiator hose, filled the coolant back up, let it idle a while, and drove around the block a few times. The idle was totally smooth and the engine temp climbed to 210 at a steady pace. BUT the accel/decel 'stiffness' remains. Anybody got any ideas?
Hows the transmission oil look? Level okay? You said you found the leak ,but the trans oil doesn't look contaminated with coolant right? If you got coolant all over the TPS that might cause shifting issue.
I doubt fried by overheating, but they are sensitive to water. Aftermarket TPS sensors don't have very good reliability either, but that would be a coincidence.
I took a look, it doesn't look like any fluid of any kind is around the TPS.
I have a trans service scheduled for Friday so hopefully that either fixes it or reveals the problem
Trans fluid drained and refilled, not much improvement. Gonna try and drive it to my normal jeep mechanic (25 mi away) and see if they can take a better look
have you tried adjusting the TCV cabl
Welp the verdict is in and the head gasket (or the head itself) is blown. Gonna try and do the job myself and save a couple grand
