mateoruiziii
- Azusa, ca
Only total 'tards would run larger tires on the front and stockers on the back!
Still got your tire winch?
We need one.
I should have it out in the garage. I'll take a look.
We need one.
The back up lights need the wire on the side of the trans connected. It was missing when I sold the MJ to Jim because the terminals broke when I pulled the engine and trans to swap the current motor in. You need the wire from the side of a BA/10 from the junkyard.
converting a manual MJ (or XJ for that matter) to auto is pretty involved, you need to swap most of the wiring harness out for one from an auto XJ/MJ. That's a huge pain in the ass (I know I've done it twice now).
x 100000000
With a low enough TC set up Beamer should be fine.
x 100000000
That's an RE HD double shear track bar.nice... I'm running almost the same setup... RE Standard duty, onto a double shear bracket.
FYI the axle side mount causes suspension bind for the passenger side droop... its a problem with the shitty factory suspension geometry. not enough lateral movement allowed.
you may want to look at re-designing the mounting location to realize the full potential of those nice shocks
yup. All 14 wires. It's a bitch.
The hardest part is changing the brake pedal and shifter assemblies.
