IXNAYXJ
- Wherever the next race is.
Are you still running the locker that you tested for a year?I personally tested one in my jeep for over a year with zero issues....
-----Matt-----
-----Matt-----
Personally i was stoked when i heard Yukon put out 2 new lockers, lunch box (Spartan) and the air operated Zip.
I'm glad you had no problems with your testing for a year in your Jeep. What compressor did you use to activate your ZIP?
Where did you wheel it and on what size tires and gears?
What exactly is your position with the company? From reading these posts it sounds like you may not have had the permission of Yukon to speak of these on their behalf just yet because of the way you have presented this thread.
I do like your enthusiam for the product and the patience you've shown when answering questions to the best of your knowledge without any BS.:yelclap: -B
Is it the same one you tested for the year? I was just curious to see how it's doing now after testing.I have 1 in the rear of my current jeep, which is a 92.
-----Matt-----
Ahhh, that makes more sense. I heard that guy swapped in an ARB.I actually sold my 98.
Who installed the prototype?Yeah actually he did. The Zips weren't on the market at the time. I tested one of the very first prototypes, and I think the case bolts eventually backed out on that unit. Same problem that ARB had with theirs. We have sense changed the fastners to ensure the bolts stay put.
thread on pirate claims that the smaller units (prone to housing flex) have safety wired bolts to help eliminate thisYeah actually he did. The Zips weren't on the market at the time. I tested one of the very first prototypes, and I think the case bolts eventually backed out on that unit. Same problem that ARB had with theirs. We have sense changed the fastners to ensure the bolts stay put.
Correct, they will be safety wired. The prototypes were not.thread on pirate claims that the smaller units (prone to housing flex) have safety wired bolts to help eliminate this
Safety wire? Sounds like a bandaid to me. Not an engineer, but if something was flexing enough to spit the bolts out, wouldn't it be wise to make it stop flexing instead of just trying to keep the bolts snug? If the carrier's moving that much, what's it doing to the gear pattern?
Do you think a sturdy diff cover would reduce housing flex sufficiently to keep the locker from flexing? Also I gotta say, if a company is going to market a new product that is very similar to a proven competitor, they need to price it significantly less to entice would be converts. To me $50 is not significant enough, JMHO.Sure if you want to truss the D30. Thats the only thing that will keep the housing from flexing. Safety wire is not a bandaid. Every aircraft in the sky uses safety wire.
