New to Naxja
I just need a little help getting those lines off of the radiator. I am pretty confident I can hook everything back up. I'm not sure if its the fact I have no idea what im doing or the fact that i might be missing the tool i need. I just dont know. Is it okay if i give you a call after i get off at 9?
Good luck with it Mike, I would come over but I am in conservation mode until my unemployment starts to roll in! That and I need gas to go to the Dentist teusday!
Its cool, I cant wait to see your the new xj though. I will try to come down next weekend, do you think i could get that window then? it depends on my gas situation also
the only thing i can figure out is that its a quick disconnect on the top and a hex on the bottom, I might just cut shit off and use some hose clamps instead because Aqilah is getting annoyed with me/ the jeep.
wednesday would be perfect as my fiance is going to cut my balls off if it isnt done by thursday. I dont get off until 10 P.m. is that cool? if not i could leave work, just let me know what is best for you.
Hey Mike you may need to ask a mod to delete your old account. Should have just gone to the user support section and asked for a change. Did the radiator show up?
so ive loosened the nuts that actually attach both lines to the radiator. now they move around semi-freely but will not pull free from the radiator.
alright i've gotten the top line off and now the bottom line is the only thing that is giving me shit. I called every parts store in bloomington and everyone says the same thing " you dont need a quick disconnect tool, you just pull the hoses off) so it is obviously a quick disconnect, i can see 4 metal tabs set inside the female end. how do i press all four tabs to get this piece apart? and where can i find a quick disconnect tool and a part dealer thats not sniffing anti-freeze in the backroom
