- sacramento
you'll regret not going to 4.88s. one of my rigs has had 4.88s for a long time, i like it a lot. the new rig has 410s , and leaves something to be desired, both are on 35s....
id go 4.88s.
id go 4.88s.
When pulling your pinion make a note of the shims that are on it stock. Also, read the bottom of the pinion (flat area facing the carrier). It should have a number inscribed on it (+2, +4, -1, -3 etc). Your new one should also have a number on it. They will help you with the initial shim pack. Most instructions will explain the hole add or subtract shim idea behind this in detail. And I second what blondejoncherokee said about the setup bearings. I used a brake hone to slightly enlarge the hole on the pinion bearing and the carrier bearings (very slow process) but there might be a better way to do this, specially if you have access to a lathe. They should slide on and off but not be too loose, or it will affect the settings. I also made my own case spreader for the carrier bearing preload, but have also done it without one too. Good luck
Awesome. How much did you get the front clip for?
Man, you got a deal on those fullwidths! Good to see you got the 4.88's in. Takes some getting used to, but remember the 4.0 likes to spin!
What about pics with the new tailgate I sold ya.
