winkosmosis
- Maui, Hawaii
Personal opinion. Absolutley no advantage over a 3-link, for my use that is. I had a couple of customers interested in a 4-link for Jeepspeed type applications. Where flex isnt such a concern as much as strength at high speeds. Of course 4 links are stronger than 3 in any case. It all depends on what you want to do.
The 4-link utilizes the stock rubber bushing on the UCA axle mounts. This will give enough "squish" to compensate the triangulation fighting with the panhard.
I ran the numbers using the same mounting point location on the crossmember (the LCA mounting point) for the upper and lower arms to simulate a radius arm setup. It came out with 161% antisquat, now that is a high number! You are sure to have unloading issues then. I've found that 90% or lower antisquat numbers can increase wheel hop and make you feel like you dont have a solid connection with the ground.
I'm looking at the CAD images on your website. How come you use the passenger side UCA mount? I've read that it's weaker than the pumpkin UCA mount. And since the trackbar mounts on the passenger side, wouldn't it be better to distribute forces more evenly by using the pumpkin for your UCA?
