DirtyMJ
- Prince George, BC
Mmm...
After much debate, I got annoyed and ordered hi-steer knuckles/arms for my D44. I had planned to run the grand wagoneer inverted T setup with it (it was a GW D44) but I can't seem to find one that is intact, don't want to buy one new, and figure it's probably not that great anyways. After all, it is a stock jeep part. That and I plan hydro-assist in the near future, making the cast tie-rod a poor candidate.
So, I figured I'd buy some other new parts and make myself a steering setup. (that works)
Now, I figured I'd use TRE's ES2233L, ES2234R, ES2027L and ES2026R, and use them in an inverted T setup. These are 1/2 or 3/4 ton TRE's. I am wondering if I should be at all concerned with using these in regards to strength? While they are not true '1-ton' steering parts as most of the aftermarket would like you to believe; should they be strong enough to hold up to the Hydro-assist/35s/spool/redneck driving?
I am also wondering what should really be done as far as the tubing for the steering. I was thinking I'd use something along the lines of 1.5x.80 (if I can get it...) DOM/HERW or like, as I feel it would be plenty strong (perhaps overkill? nah, that doesn't exist) and with a little bit of luck could be tapped with the 7/8-18 thread of the TRE's.
Although, I have to ask, who sells a 7/8-18 tap anyways? Definatly not a normal size. That and, what would really be the recommended tap drill for it? I ment to swing by the industrial supplier today...
Failing that, I'd have to buy tube inserts. Which I don't want to do, as I live in the boonies...
(Oh, and if you wonder why I want to use inverted T as opposed to crossover, it's because I was intending to use it when I bought the steering arms and thus they are not drilled for cross-over. I also don't want to cause too many issues with my steering ratio...)
