roxj
- the woodlands, texas
im going from 33's 12.50 15's to 315 75 16's. i was running an 8 in wheel with 4 in back spacing. should i do the same for the 315's, only in a 16 x 8 or should i go to a 16 x 10? what back spacing would you recomend?
my current set up consist of re drop brackets , jks adj uppers and lowers, 8 in sky jacker coils, a re hd track bar and bracket, and a skyjacker drop pitman arm, with re 4.5 leafs, 1in block and 1.75 shackle and rancho rsx shocks .
probably more info than you need but now you know what i have to work with.
tia
trey
tia
trey
