100K XJ
- Rocklin, CA
Hey Illustrated, apparently I fail at PM'ing, just letting u know I got the message...sounds good
Yeah. Do it right.
Layer of black... red lower half with a tongue, then white teeth over the top. Then clear coat!
I also installed my switch for disengaging the annoying beep when the keys are in in the ignition, I hid it pretty well I think, it sits right behind the hood latch:
I have some extra pics and info on the first page of the blog, but when you take off the kick panel there is a connector with 3 wires, the middle wire (at least on the '99 and '01) causes the beep, and can be cut and bypassed. If you disconnect the entire connector the beeping will stop, however your dome lights will not turn on when the driver's door is open.
