my 91 xj build thread
thanks guys, and good to know about the welds, i pretty much just figured out the settings from trial and error based on how fugly they looked.
got all the little plates made today. about time to start welding.
picked up a ford high pinion d44 this morning. it has the right gearing already, just need to order a stator kit for my elocker, and find some waggy shafts or something for when i shorten it. guess i need new wheels too....
ill probably still slap in the built d30 for the time being and take my time with the d44. i want to go coilovers in the front eventually, so i think i will wait until i have those before i swap it in so i dont have to weld on coil buckets then cut them off.
due to the shitty weather, i didnt get a whole lot done today. got the access holes cut out, got the frame stiffener section on one side welded in, and all but one plate welded in on that side. i still have some welding to do from underneath, but it's raining and i didnt feel like doing it. i'm pretty happy with how it came out so far, it is solid as hell. i do not think i'll need a cross brace between the two, it's not going anywhere.
i still haven't even welded the gusset sections to the frame stiffener, so it will only get even stiffer. in hindsight, i think 3/16" plate was overkill, but oh well.
had a little trouble getting a decent bead in some of the tighter corners, but it will hold. everything fit together fairly well.
plates that tie in the body to the floor and wall.
