motor mod 1990 cherokee
articus
albeta
I have recently purchased a 1990 cherokee pioneer, only to find out a 1994 high output motor was put in. Now I am not complaining! I was able to determine some vacume lines were plugged or hooked up wrong. Any ideas how to make sure the rest of the swap was done correctly? Art
does it run? run good? if so, then your probably fine...but you can also get a chiltons and look around that, just to be safe
are you sure it has a 94 motor in it?
Actually, your best bet would be to find a stock '88 thru '90 CJ 4.0L and park yours next to it. Pop the hoods (helps to get the owner's permission first, of course) and compare.
A 1987 will be very similar, but because '87 was the first year for the 4.0L there were some running changes that may appear different from your '90.
The year of the head is stamped on top, need to remove valve cover to find it. Unless they just slaped the HO heads on the stock block, it could be a complete motor.
