Lowrange2
- Abbeville, SC
GM 3.8 V6
Psh... Not in my experience.
I spun a rod bearing in my wifes a while back and a buddy of mine has put three of those in his buggy.
GM 3.8 V6
I think that's the engine that was in my buddies WRX that blew up 2 days after he bought it...
The 25D was in the Legacy and outbacks and the 98 impreza RS. They are finicky engines to say the least but if they are well taken care of they can go for a long time. Mine is at 196k.
As for reliable consumer engines don't forget about the Cummins B5.9!
Do those count? All of the Cummins engines were designed for commercial applications. They were never designed for the consumer market.As for reliable consumer engines don't forget about the Cummins B5.9!
new cars sure... I would put money on any one of my jeeps surviving 100% rated power (or more, rated power is at 4600rpm on the 4.0 iirc, I've kept them at 5250 for hours on end before) for several tanks of gas with no damage.Take any new car built, break in the engine correctly, and set it up to run at 80% rated power,.. It'll be trash in under one tank of gas.
Defiantly the slant 6.
My dad used to own a repair shop back in the 60's and 70's. At that time independent shops did a lot of warranty work. They had one come in that had a slight knock and Chrysler told them to blow it up.
So they took it out back and stuck a brick on the gas pedal. Remember, this was long before computer controlled vehicles with rev limiters. After six hours of this thing running wide open they got sick of the noise and poured sand down the intake in order to get it to quit.
Six hours does sound a bit optimistic, but then again, I once had a (or rather had custody of a work related) 60 Valiant with the original slant 6, and I think that one would run on the promise of gas tomorrow. The Valiant, rusted to oblivion, with door hinges and tailgate broken, some damage from a previous engine fire, transmission barfing out fluid and taking a good ten seconds to engage from a stop, as well as (really!) missing half an upper ball joint, so that the top of the knuckle simply rode in the hole, finally committed suicide, by popping out of park and releasing its brake on a hill. It rolled, still running, into a tree, which put the fan through the radiator. We didn't even shut the thing off. The local dump at that time took whole cars, so I called on a cow-orker to convoy, and drove it the ten miles or so to the dump, sans coolant. It ran like a champ all the way, and didn't start seizing until I let up on the gas at the final moments.my vote would go to the 225CID slant six as well, but I find it hard to believe one ran for 6 hours at W.O.T.-- I put 320,000 on one and couldn't get more than 4hrs @ 60-65mph. The only thing that would almost let me believe the tale is that the 1bbl carb was small enough that W.O.T. might have been about 65mph! Mine, sadly was the "super six" in a Volare wagon and it had the 2bbl carb.
While I own three 4.0's, and love them, the engine with the highest mileage, and works the best, is the 2.3l in my 99 Honda Accord.
Till you forget to replace a timing belt. BOOM
No mention of the 2.3L Ford engine, those things are pretty unstoppable as well.
i had a couple 2.3l rangers, those motors are bulletproof.Damn! I forgot that one too. There was only 2 things that would kill a Pinto, getting rear-ended or rust. Those were some tough little sob's
