tbburg
- Scottsdale AZ
While there are a few V-8 fans, we seem to be converging on the straight-4, 5 main bearing, and straight-6, 7 main bearing engines.
True enough. There are some fine V-8's (I did nominate the Chevy 350, for example), but I still think that for just plain durability, few things will surpass the classic American cast iron pushrod 6. Choosing which one is the best is going to be kind of like shopping for anvils.While there are a few V-8 fans, we seem to be converging on the straight-4, 5 main bearing, and straight-6, 7 main bearing engines.
I'm surprised nobody's mentioned the Chrysler 2.2 yet :dunno:
True enough, and one of the most useful anvils I ever had was the block from a '51 Chevy straight 6!Hey!.. watch that.
The right anvil is important.
ive taken mine from 96k to 139k with a bad wrist pin. still chugging along and sounding like a diesel. I've rarely seen them with over 200k though.
Do those count? All of the Cummins engines were designed for commercial applications. They were never designed for the consumer market.
I believe the 5.9 Cummins was originally designed for a stationary power generator. Made to operate endlessly (literally never shut down except to service) In that mode, it's common for them to run for a month at a time at rated power. Mounted in a pickup, that engine's loafing.
If you want to throw in commercial applications, any of the over-the-road semi engines will blow any car engine into the weeds. Half million miles? No problem.
Aircraft engines are the same. 2000 hours at 80-100% rated power? Normal operation. Take any new car built, break in the engine correctly, and set it up to run at 80% rated power,.. It'll be trash in under one tank of gas.
But can you size a horse-shoe on it?True enough, and one of the most useful anvils I ever had was the block from a '51 Chevy straight 6!
fixedI'd have to say I disagree with your assessment of the AMC 4.0 While they can be torn up, and there have been a few duds('00 0331 head anyone?)The renix, OBD, and first gen HO series all seem to last 200K with brutal abuse. That is head and shoulders above the crowd. But yeah,. it's not longest lasting. My vote still goes to the Chrysler slant-six.
I do have a proper anvil although I never got into horseshoes, but seriously an old engine block is a very useful home shop accessory, giving surfaces to beat against, support for welding, and an assortment of holes for bending or holding work. Torch cutting over a cylinder hole helps to contain the slag and sparks, too. As a sort of souvenir of my first car, I still have the stripped block from my '59 Peugeot in the shop.But can you size a horse-shoe on it?![]()
and i wont buy jap crap again.
what argument? that was a statement. I've had several STOCK, well maintained Hondas, and they didn't hold up to my abuse. i averaged 2 motors a year, plus transmissions (manual, not automatic). If they didn't spin a rod bearing, they smoked like a chimney. If the car had any real torque, it'd rip itself apart. I've built things out of legos with more structural integrity. The one with the higher mileage (172k) rattled more than my jeep. I've had probably close to 30 vehicles at this point, and the Hondas were by far the worst of them. And i even owned a Chevette if that tells you anything. If you drive like a little old lady, they're probably fine, but i'm very, very, not nice to the right pedal.Really dude? This argument is pointless. My brother has had 4 hondas(all of which are well beyond 100k), the 92 accord coupe he had was bought by my mom at just over 200k and lasted my brother to 263k, this was with very little maintenance and lots of abuse. The trans finally let go on it as I was driving it. his first honda was a pile because it was a carb'd one. I wouldn't own one to save my life. Honda engines are great as long as you keep them stock and don't throw boost at them.
in that you can still smash your fingers with it even if you break the handle off? :gee:It was uncompromisingly, unapologetically, big, noisy, thirsty, heavy and smelly, and as reliable as a hammer.
