theres just bubbling in the bottle...asked around and thats what seemed to be the most common answer...aside from that when the trucks overheat on base (closed system) thats the sign for air in the system. im just going off that...
bubbling in the bottle is the air leaving the block and ending up in the bottle where it should be. just keep it at the full line you should be good. if its not overheating dont worry about it too much.
Are you filling your bottle up over half way? If you look at the bottom with the cap off you will see a nipple that has to be under water.. I fill mine up almost 3/4 full then let it run with cap off.. Just top it off when it burps
im going to go look at it tonight and see if i can figure it out...i printed up the link grimm gave me and will do it over again...maybe theres something that i missed!
