besthaticouldo
- St Louis, Missouri
man i wish this was closer...this is just tooooo far for me
id love to meet some of you tho
If you can bring them rock rails I can bring the money and we could exchange them if you still have em.Jump This said:Its tonight?
:banghead:
Let me see if I can wake up in time!
Damn! 0100?! I was in bed asleep by then after my 1hr+ drive.Xtreme XJ said:It was nice to meet Jeff... knew all the other sacks... I think it was 0100 hrs. when Jeff & I left...
The Country Crapper... camera flash... Hiway Patrol... a blown Dodge motor...
Anyone talk to Cory ??
Good Times... I'm glad that whoever decided to wait till this date did... THANKS !!
Curt
P.S. Rick you SUCK !!! a leak... HAH !
Darky said:Damn! 0100?! I was in bed asleep by then after my 1hr+ drive.
Xtreme XJ said:Yeah I'm a little long winded... Momma even called think'n I might be at 7th. Heaven with Rick... :wave1:
Curt
Curt
Ditcher!1xfloppy said:had some overheating issues...so i had to head back to my buddys house and try to fix it...hoping that id still be able to make it...it ended up being 1030 saturday evening before everything was taken care of...sorry guys
Darky said:Ditcher!What ended up being the issue? I'm fairly certain my fan clutch is bad so eventually I will install the new one I bought like 3 weeks ago...
jack the rear of the jeep up as high as you can get it, run the engine till its at 210, then shut it off and pull the temp sensor out of the rear of the head. if there is air in the system it will all be trapped right there. or, if you feel like pulling the tstat out again you can drill it so it bleeds the air out itself. check out this thread http://www.naxja.org/forum/showthread.php?t=939188&highlight=drill+tstat1xfloppy said:t stat and now air in the system...
GrimmJeeper said:jack the rear of the jeep up as high as you can get it, run the engine till its at 210, then shut it off and pull the temp sensor out of the rear of the head. if there is air in the system it will all be trapped right there. or, if you feel like pulling the tstat out again you can drill it so it bleeds the air out itself. check out this thread http://www.naxja.org/forum/showthread.php?t=939188&highlight=drill+tstat
this link may prove helpfull as well, taken from the drill thread.
http://www.lunghd.com/Tech_Articles/Cooling/BurpAirMod.htm
