Ford TTB is not a dual wishbone setup. yes is is independent and therefore unrelated to stock cherokee suspension other than it has coils. when you convert your cherokee to long arm, in most cases you are converting to a radius arm setup and that is where the comparison is. the TTB is two lateral arms with one pivot point each, that move in an arc. that much is very different. when viewed from the side though, those arms are located by a radius arm, just like the long arm cherokee setups. when the axle moves up and down, it is forced to move backwards, thus changing castor. when viewed from the side ford TTBs exhibit this same characteristic. so they are similar in that there is a lot of castor change during suspension cycling. (TTB and long arm Cherokee)
