I don't know if there are many long arm kits comercially available other than the Skyjacker. Most fab up their own or have them fabbed up. Another good choice are the RE drop brackets. They use standard length arms but drop them down a bit for improved angles
PS- The front upper & lower control arms are ALL of the control arms on an XJ- Unless you've converted the rear to coils!
Hey nik, check out claytons longarms, thats what I have and they are well worth the money. I have absolutely no complaints or anything I would change about them. later
-calvin
Expensive, what did you think would happen when you lift to 10", even 4.5" - 6" is expensive. Just compare XJ kits to other 4wd's out there, those IFS lifts are expensive and you don't get near the lift or flex out of them.
The other thing is you going 10", most kits out there really were not advertised to go over 8", goodluck.
I am running Tomkens Long arms along with REs trackbar in a custom bracket and skyjacker 8 inch springs with two inch spacers. So far I have mostly liked Tomkens long arms with the exceptions of one thing. I wish the crossmember-LCA mount was held on a little better. I think this is something that could be fixed with a little welding and a little thought
nope, definietly wouldn't be able to use them. The rears will be much longer than the fronts. If you want to do the rear conversion check out www.rockkrawler.com they sell their rear conversion with coils for 2199, but pm me for a discounted price.
Someone was asking about the prefab rear coil over mount, I will try and remember to take a picture for you when I'm up at the shop.
My vote is for RockKrawler LA's one of the more inexpensive kits and one of the strongest kits. It also flexes and rides like a dream.
