Keeping A Low Center of Gravity.
I'm shooting for 2.5ish and 31's i may go up a little more than that but I like how it does now with basically no lift and 235/75/15's It just need s a JCR belly skid and a wee bit more clearance and I'm content.
Aw, come on...
You know the roof is made of the same stuff they stamp license plates out of.
I can balance out the entire roof stucture by eating a double whopper with cheese for lunch...
Robert
Robert, that is friggin Hilarious!
i have 235's and basically 4 inches of lift plus some trimming, and im torn between 31's and 33's, i want to go 33's but treadwright.com doesnt have any i like and i want to try a set out to see if they are any good. last time i went to the desert i liked having my full 6" of uptravel when i went over rocks and hit unexpected dips in the roads. but i didnt like dragging axle if i didnt go over some rocks, im not a serious rock crawler so overall ground clearance isnt a huge issue so idk if i should try 31's and go 33's later or vise versa
I bought my Jeep with bald tires, I aimed for 0-1" lift w/ 30's which happened.
That then turned into 3.5" with 30's.
Then I was dicking around on craigslist and found 33x12.50 ATs and thought "I could make those work"
I made those work (they had minimal backspace and stick 4-5" out on each side of the Jeep after the trimming, so I made myself some fenders out of lawn edging (so they would pass MA inspection, I have been told on multiple times its the cleanest "XJ lawn edging job" the person has seen:roflmao:).
Now I think it looks mean and wheels well enough... but would look meaner and wheel better if the fenders were tubbed and I had 36's with MAYBE another inch of lift and full width axles (and 2" more backspacing so the width stays the same :D)
So much for a cheap rig. At least it's not my DD anymore. Aiming to have the floor pans replaced by the end of Nov so that I can drive it should we get a mean storm, but right now it is 100% off the road. Makes me sad :(
If you are staying low and looking for clearance, I suggest you look at TnT's belly skid. It replaces the stock crossmember, and gains you about 2" under the rig.
http://www.tntcustoms.com/page.asp?pageid=173
If you intend to do any hard offing that belly armor is a must. I'm at about 2 with 31 or 235 and spend more time on my skids then my wheels :) and don't forget the tank too.
Just went through this whole thread, one common theme I kept seeing was busted up fenders. I'm not saying a LCG with big tires is a bad thing just pointing out what I kept seeing.
That's what comes with owning a cherokee and putting bigger tires on it. You gotta do a whole lot more work to fit them and sometimes you still rub all over the place.
I have 4" lift, 31" tires and only 1.5" uptravel after bumpstopping it enough so that my LTB's don't rub. Kinda sucks but oh well. I'm not into cutting up such a nice jeep.
i like the look on yours with 31's, i traced my stock fenders out and trimmed my fenders that way, if i wasnt on my phone id post pics but im looking to go 31's like you did, looks good
i can thank the ninja trees for my last rig.
my new one ( 3" and 33's) i'm not able to trim as much due to the washer fluid bottle so they do contact a bit, some bumpstops will alleviate this once i get around to it.
I tried to stay as low as possible and run as big of tire as possible with my build. I am really happy with how it turned out. I used a trailer fender to make up the difference in the back between the two layers of sheet metal. I am going to tons and 40's next. I am going to try to keep the same height. Of course this picture was taken at the end of the build, before all the rock rash and dents.
:loveu::thumbup::thumbup:
Very nice rig man!
this was just after the lift and before the trim sitting on 235's still
right now i sit like this... i dont want to trim the plastics because im getting a winch bumper to replace the front and the rear will get replaced eventually, just gotta decide if i want to go 31's or 33's
really like the ability and look of this one...low COG or not. nice rig.
:sad1: He likes my Jeep... Tomorrow i'm putting on a 3.5" on my friends back halfed xj. Rusty's 3.5" leafs and zj coils with spacers, he's thinking of going 33's. I'm taking him on has first trip to moab in a few weeks so that will help him decide on tire size i think. But he'll will run the 245's he already has till the money rolls in for new or used rubber. i think that should qualify as low CG.
besides rocks and trees hitting them it can just simply be due to lack of trimming and/or lack of bumpstops. i have a dented fender from my tires rubbing......i have 235/75 r15 BFG A/T which is about a 29" tire.
you will HAVE to either bumpstop and/or trim if you get bigger tires, taller lift or not.
i never flexed into the fenders no matter how hard i tried at stock height and 235 bfg mt's... i still have stock wheels though
I've static flexed my 235 bfg at's (on stock wheels) into the flair, don't know if it'd be much worse on a big bump.
