June ROTM voting thread
vote!
  • robz95xj
    Votes: 33 31.7%
  • xjeeper
    Votes: 39 37.5%
  • foxwar71
    Votes: 13 12.5%
  • garrett83
    Votes: 16 15.4%
  • rockclimbr
    Votes: 3 2.9%
  • Total voters
    104
XJLI
Long Island, NY
Once again guys, work has been crazy.. sorry i've been a little late with these.
anyway, VOTE!!
ROBZ95Xj
1995 Jeep Cherokee Sport
4.0 AX15 4.3 Atlas
Frt supention
3link
4.5" RK Coils
extra coil isolators for total of 5.5"
Bilstien 5100's
Rear suspention
5" DPG leafs
shackle relocation boxes
.75" Rustys shackles
.5" lift blocks
total 5.5"
daystar prgressive bumpstops
BBCS shocks
87 Ford F350 hp60
5.38's lockrite
10 factory shafts
poly performance drive flanges
Ried Knuckles
Balistin hi steer arms
RS Cover
Rear Axle
92 Ford E350 D60 ISU
Yukon 35 Spline Shafts
5.38's
Spool RS Cover/Disc Brackets/Simple swap kit
42" Pitbull Rockers
Hybrid Cage
Custom bumpers and rockers
Belly Pan
Tractionbar
Battery Relocated behind pass seat
summit 16 gallon fuel cell
XJEEPER
2000 Jeep Cherokee Sport
Under Hood
4.0L Motor
Fastman 62mm throttle body
Flowmaster Muffler w/hi-flow Cat
AEM Dryflow filter on custom intake tube
Optima Red Top battery
Viair 450 Air Compressor on custom bracket
AW-4 Tranny with Shift Kit
231 T-Case w/32 spline shaft
Tom Wood’s Custom Driveshafts SYE
Woody’s Front/Rear HD Driveshafts
Drivetrain
HP D30 with ARB air locker-30 spline
30 spline Alloy USA axle shafts
Alloy USA tube seals
Rotated and gusseted housing inner C’s
T&T Customs weld-on Truss
Custom LCA Skids
Custom Upper and Lower shock mounts
Custom Trackbar w/JKS axle bracket
Custom trackbar truss/crossmember
Ruffstuff HD diff cover
WJ brake swap with Akebono calipers
Custom 1.25” DOM steering linkage w/Tera TRE’s
Currie Anti-Rock sway bar with custom brackets
Prothane coil insert bumpstops
SS Long-travel brake lines
XJ D44 Rear with ARB air locker-33 spline
33 spline Alloy USA axle shafts
4:88 gearing
TJ Rear Disc brakes
Ruffstuff HD cover
Extended Bumpstops
Raised shock mounts
1.25” Billet Wheel Adapters
285/75/16 Maxxis Bighorn tires mounted on Jeep Moab wheels
Suspension and Chassis
T & T Customs Y-Link Arms and Crossmember
RE 5.5” Coils with .75 poly spacer
RE 1463 Leaf packs 3.5”
2” Custom anti-wrap spring perches
1” Custom boomerang shackle
Bilstein 5165 Front / 5150 Rear Shocks
T&T Customs weld-on Unibody Stiffeners
Temper Mental Racing reinforcement plates
JKS SBS plating-both sides
Armor
Custom Tube Front Bumper-1.5” DOM
Custom Rock Sliders 1.5” DOM
Custom 1.75" DOM Tube rear bumper -in progress
JCR Rear Qtr Guards-in progress
Miscellaneous
Bushwacker Flat Flares-painted to match body
Hella H4 headlights w/upgraded harness
Front Door storage pockets
Custom rear passenger seat headrests (ZJ)
Custom ARB plumbing with manual pneumatic switches
2 Gal Air storage tank
Uniden CB w/ Wilson 1000 roof mt. antenna
Fire ext , 1st Aid kit
Recovery straps , clevis, tire plugs, HiLift jack, LoLift Jack
foxwar71
1999 XJ
-Stock 4.0/AW4
-Stak 3spd monster box (1:1, 3:1, 5.44:1)
-Triple sticks
-Cut/sleeved XJ driveshafts
Front axle
-Narrowed late 80's HP60
-5.38's/lockrite
-Ten Factory shafts
-RuffStuff cover
-3x6x5/16 truss, Clayton coils buckets notched in
-Inner C gussets and heavily modded/plated ford knuckles
-NWF high steer arms and 7/8" heim steering/trackbar
Rear axle
-88+ C&C 14b
-Super shave job and turned 5.38 ring gear
-Orb of Traction
-RuffStuff disk brackets/shaved cover/pinion guard
Front suspension
-Mid-arm 3 link with Ballistic joints all around, 2.25" x .375" DOM lowers
-12" short body 7100's 360/80
-3" Prefender air bumps
-T&J-style upper shock mounts
-Engine cage to support shocks and bumps, ties into engine mounts too
-PSC hydro assist setup with remote resi and cooler
Rear suspension
-RE 3.5 leafs with 2 bottom leafs removed, 1.5" Teraflex shackles, relocated mounts
-Adjustable UBE's and front hanger
-12" 7100's 275/78 on hoops thru the floor
-Poly comp bumps
-Monster-sized RuffStuff traction bar
Tires/wheels
-17x9 black steelies with 3.5" backspacing
-DIYbeadlock flipoff smiley rock rings
-InnerAirLocks beadlocks
-37" stickie Maxxis Trepadors
Misc
-Full 3/16 frame plating
-Full hybrid cage and chopped rear roof
-Dove nose with more tube up front
-Dove tail with tube and skins
-THE Kastein's old MJ tailgate chopped up to it the tube
-No more lights or useless wiring
-Tucked bellypan and crossmembers
-Raised 2x6 rockers
-1/2" thick plastic skid on the belly and boatsides
-Superwinch 8500 behind front crossmember
-Raised gas tank
-Half doors with built-in cupholder
-Brown Dog rubber motor mounts and super block brackets courtesy of the NACfest 11' and NACfest 12' raffles
-Cowl intake
Coming soon
-Cruisin' USA arcade game shifter wired for full AW4 control
-An instrument cluster that works
garrett83
91 XJuggy
Custom everything
Lincoln locked Dana 60s front and rear
5" lift
Long arm 3 link front
Bastard leaf pack rear
39.5" TSLs
1.75" DOM cage
Raised stock gas tank through floor
Bilstein 5150s and white bodies
Warn M8000 winch
3/16" frame plating front to rear
1.5", .25" wall DOM tie rod, drag link, and track bar
Poly bumps front and rear
4 bucket seats with 4 point harnesses
Much much more planned for the future...
rockclimber
Specs
99XJ 4.0 AW4 NP231, 33"s
Front end
HP 30
4.56
Warn Chromos
CTMs
5-4.5 Hub kit
Vanco 16" brakes, Black Magic caplipers
ARB
Rear end
Chrysler 8.25
4.56
Ruffstuff Cover
Polyperformance Shock mounts
Suspension
Front
Currie 4.5" coils
Rokmen Johnny Joint Arms
Currie upper Johnny Joint Conversion
Ruffstuff Panhard
Bilstein 7100s, 12" Short Body
Prothanes
Rear
RE 3.5" leafs
HD offroad Gen2 relocation brackets
RE 5" shackles
RE 10.5" monotubes
misc
Currie Steering
PSC large bore box/Hi volume P-pump
Custom(homebrew) Transmission raise/flat skid
Dirtbound Offroad Hack-n-tap SYE
Hella 700s
Actionfab Frt Bumper
Homebrew Tire carrier rear
stinger
2x6x1/4" rockers
Dents
Daily Driven
coming up
8.8 rear,super88,ARB, Truss
Artec D30 truss
35"s
Warn M8000
So, who won?
Voted for the really nice straight bodied one.............mine used to look like that.
