ColoradoRaptor
Headbanging Hillbilly
- Canon City, Crawlorado
Still need to check on my t-case issues, plus I think my rear diff is howling, and there is a nice new pop in the front end now!.
Sounds like mine So drive it already :spin1:
oh NOOOOO.....hopefully this new water pump install goes well! otherwise I may not be able to make it...
Skully said:Then head out and I will probably head out 104th to HWY93 pass by Hypoid and make fun of him, then up 72 through Blackhawk to Rollinsville.
Let us know, hopefully the water pump won't be too hard of an install. I remember mine was a pain only cause you have no space to do shit.
Did you pull the grille, and put the radiator aside? That opens things up very nicely!
CYA there! Have a safe drive! I will PM you my cell in case you lost it.I am going to be at the Post Office in Rollinsville. I am shooting for 9am. See you all there :cheers:
So this won't get lost in the thread.
So far we have:
1. Skully (might have a buddy in a JK)
2. Jeepfreak (might have some other friends from school)
3. XJcase (maybe now)
4. Coloradoraptor
5. XJgirl (maybe)
I plan on picking up my navigator at 7:30ish and heading out 80th Ave. If you want to meet up at the Ralston high school which is just off of 80th ave. We can head straight out from there to Coal creek canyon up to Rollinsville.
Mapquest link of Ralston Valley high school We can meet on the south side parking lot.
See you guys in the morning!
XJCase & 90Xj girl let us know what the deal is............
That is another hours worth of work, it was easier to cussed and cursed instead and saved 1/2 an hour.
10-15 minutes tops to pull and replace. Plus with all the coolant lost when you pull the old pump it would be a good time to do a flush and add all new coolant.
O ya forgot about your fancy winch!It is harder with a winch in the way and when I did mine everything was brand new, radiator and fluid. 1/2 hour to take off and 1/2 hour to put back of extra time.
......go fix you dang transfer case, sheesh! :repair: :twak:
I am going to look at it when I get off of work, plus I think the poping noise is just those damn LCA bolts getting loose again. I think the anti-seize has turned into anti-stay tight as I have to tighten the bolts every month or so. I may still join in on this run, if I do go it will be very last minute. I will let you know.
So far we have:
4. Coloradoraptor
5. XJgirl (maybe)
4. Coloradoraptor
5. XJgirl (maybe)
6. Beezle
I already ran this trail a couple of weeks ago but wouldn't mind heading up with you guys tomarrow if everyone doesn't mind. About what time do you think you will be at the high school Skully? I can just meet you there and head out.
Ok well doesn't look like I will be able to get the jeep ready in time.
So far we have:
4. Coloradoraptor
5. XJboy (a low maybe)
6. Beezle
To Caravan up Coal Creek Canyon drive If you want to meet up at the Ralston high school which is just off of 80th ave. We can head straight out from there to Rollinsville.
damn... you gettin up early before the chickens ain't ya!:shocked:I am going to be at the Post Office in Rollinsville. I am shooting for 9am. See you all there :cheers:
