Ok, so this is the way I see it at the moment.
1. Skully
2. Jeepfreak
3. XJcase
4. Coloradoraptor
5. XJgirl (maybe)
Wow, Ira actually driving up to wheel with us? I am in awe..................just giving you shite Ira, it will be a pleasure since last I saw you was the gear and parts run a year or so ago. You bringing your boy? I was bringing both youngsters plus a special guest. My old wheeling dude that lived with us (adult foster care.) He is going to be part of my marketing for the wheeling adventures I am trying to put together.
XJgirl hopefully you can get you Jeep in good running condition for the trip.
I actually came home from work at 4:30, the wife and kids were napping. So I started the project to replace the passenger side motor mount, took all of 1 1/2 hours.
Had to change oil of course as to do it as you have to removed the filter and adapter piece to get the Damn bolt out for the motor mount.
I found all three bolts that hold the bracket on the motor were finger loose, so saved again by odd timing. Could imagine those bolts vibrating out and dropping the motor on the passenger side. Not an easy trail fix..............
BTW why in the hell did Jeep use two hex head bolts and one
torx head bolt to button up the bracket? stuuupid, hard as hell to get enough pressure on the socket and tighten at the same time!
I am not sure about a Caravan, Jeepfreak doesn't like my path I guess. I have to pick up my co-pilot at 7:30 at 84th and federal area. Then head out and I will probably head out 104th to HWY93 pass by
Hypoid and make fun of him, then up 72 through Blackhawk to Rollinsville. Anyone wanting to meet on that path and head up together let me know.
XJboy you still pondering??
