I
Iron Rock
Guest
Any thoughts on making the upper arm not fixed to the lower arm?
Nope. This has been a feature that's very highly praised by our customers. It's strong, and looks cool at the same time.
but doesn't it bind? When one tire droops and the other stuffs without a joint where the upper and lower meet it seems like it would bind. so then it has to flex the joint/bushing at the frame end?
I'm barely knowledgeable at how it all works so if I'm wrong teach me something.
There is virtually zero bind in this set up. Like mentioned before, the joints on the frame side have a high degree of misalignment, so all the rotation you need is available in those bushings!
there is bind, thats why you have those rubber bushings in your arms.
well that's not quite fair, every setup has bind somewhere
All suspension setups will eventually bind, no matter if you run Iron rock, or any other.no they dont.
x2 All suspension setups will eventually bind, no matter if you run Iron rock, or a custom 4 link.
Iron Rock isn't wristed...
there is zero bind in the iron rock setup.
then what would you call it?
its the same concept as wristed ford radius arms, just mounted differently
think of it as a radius arm 3 link. which we all know will flex with little or no bind.
IRO as did RK marketed a system with 1 uca, why haven't others? i think it's a liability issue.
It's not so much a liability issue. It's more of a consumer confidence issue. Many people, who do not understand how a three link or radius arm system works will shy away from a kit that goes against the factory link system and only uses three. This is scary to them and seems unsafe. You can bet your bottom dollar that we are going to start seeing manufacturers offer 4 link suspensions that give you the option to easily unbolt the 4th link, creating a three link. It is easily marketed and will gain trust amongst the uneducated suspension buyer.the liability comment i made was speculation only,since there seems to be only 1 mfg of a mass produced 3 link and 1 with a radius arm set up with only 1 upper arm.point was both of the systems have very little bind so why just two.also both of the above mentioned systems use quality materials.i also used the term radius arm 3 link for lack of better description. bottom line is both systems flex a bunch and have little bind.and share the same mounting points. maybe i should have said radius arm 2 link! have a good one!
