Important
check the passenger side footwell for the PDC. There's a grommet that leaks, the connector catches and holds water and the bottom two rows of pins corrode.
it will kill the dash/radio/rear defrost and o2 stuff first.
It will keep it from starting.
BTDT hot glued new spade connectors in it the night before I left for chicago.
Which connector? I unplugged the CPS and reconnected with no luck.
My LJ has thrown a different code every week, non of which affect how it drives, I am about to pull the ****ing bulb.
Man, it is hot out there walking, someone decided to steal my battery today.
So i found this in my shop. Now can anyone explain how this ancient thing works?
Ill be cleaning all the grounds as soon as im off work
Do any of you guys have insurance on your home tools? If so how did you go about inventorying them?
I started organizing my stuff at home and figured I should probably add that to my insurance.
