its a 4.5" rough country lift. i got an alignment on it done thinking it would solve it but im still having trouble with it. i live in La Habra. wats the toe??
Well everybody's said just about everything so i'll throw in my 2 cents worth. A bad tie rod end on the track bar was the culprit of my death wobble. HTH.
you need to check every moving part in the front end.
upper control arms - check the busings on both ends.
lower control arms - ^^^^^^^^^^^^^^^^^^^^
Tie rod ends - check for play (they should pivot around the stud but be a little hard to move, and have no up and down play at all)
track bar - you say you have a 4.5" lift, you should have an adjustable track bar on there then. make sure its adjusted correctly per the instructions in the kit, and check the bolts on both ends to make sure they are tight. loose track bar bolts are the culprit 70% or so of the time. Also make sure the bolts holding the frame side bracket are tight.
hubs & ball joints - jack the axle up one side at a time and give each tire a good shake. you shouldn't be able to move it any way but turning it. grab the top and bottom and try to move the tire forward and back, and push the top & pull the bottom and try to move it that way. if it moves at all take it off and start looking at the hubs and the ball joints.
good luck. like i said check anything that moves. something has some play in it - you just haven't found it yet.
I have a 97 xj and had death wobble on it, I could not reach 25+ mph, and i put a steering dampener on it and it took some of it away, but I just need to tighten the track bar down and hoping it should be fixed but you should try a dampener it could help.
my stabilizer makes swishy noises when I take it off and cycle it, I just put it back on for looks
The general oppinion around here is the steering stabilizer will just mask problems that you should fix anyway. plenty of rigs are driving around without them and have no DW whatsoever.
