CanMan
- Lake Tapps, WA
Well my buddy thinks your buddy is an idiot.
Or you could search on how to redrill the hole on the axle end over about 1", and up 1/2" to get the front end closer to being in there straight.
Edit: Sweet, finally made it into someones sig.![]()
yeah, everyone hate's rusty's right? then why did the guys at 4wp's suggest me to go to rusty's for the track bar? they were like if we could carry them they would...
but if i remember correctly, it was their lifts not their LCA/UCA's or trac bars.
MaxxXJ
gawd dammit! NO Rusty's Trackbar. If you get one anyway, then don't be surprised when it fails or breaks on the highway. I get angry because its like sticking a loaded gun to your head. You KNOW its not a good idea but people do it anyway and get themselves killed. Not everyone who works at 4WP is smart enough or has enough actual offroad experience to make good recommendations. They just pimp their parts or pull the first product that comes to an empty mind.
Here's my experience:
search for the TJ who rolled his rig completely on the hwy. The rusty's trackbar broke.
right now im on a budget, i dont work currently so i need a cheap fix and drilling over 3/4 inch is not an option.
im just curious if it's because the TRE was cheap and bent and if i could just replace it with a better TRE or whats the case yanno?
skyjacker has their track bar relocation bracket i am going to look into unless you guys have a bad opinion of that as well.
Why?
You have no money, but dont want to do a free mod? You would rather drop some coin on a cRustys track bar, have it fail, and destroy your jeep?
Good luck pal.
free mod = drill over 3/4" ?? ...........is them drilling a hole 3/4" over going to weaken the track bar mount much?
Yes, drilling over is a free mod IF you have the tools.
And no, you'll be ok until you get a real trackbar.
Not really, a steering stabilizer can only mask DW, and keep it at bay for a while. If it is blown, it is no longer doing its job, and is not dampening the oscillations. This then allows the DW to show through. But, something else is the root problem. Steering set ups are not designed to give you DW if you don't have a stabilizer on it.-Bad steering stabilizer. YES, this does matter. This is what was causing mine. believe it or not, without the stabilizer I got DW after every pot hole I hit. Make sure you have one and it's not blown.
free mod = drill over 3/4" ?? if i can get the track bar relocation bracket for less than 30 bucks, i'd rather do that, but if its going to destroy my xj, then thats not exactly a mod either... but apparently the alignment shop says " oh we drill new locations like this all the time to align the vehicles"... is them drilling a hole 3/4" over going to weaken the track bar mount much?
This is what I thought too, but I call shennanigans. When I put on my budget boost, I replaced the steering as well. EVERYTHING. Ball joints, zj tie rod and ends, track bar bushings, drag link, and steering stabilizer. Had an alignment, balanced my tires. The steering stabilizer was the very last thing of that whole sequence to go on, and I had DW until I put it on.
