hp30, beadlocks & wheel spacers
Rob707
sacramento
Front axle and wheels will be pulled in a couple weeks. Spacers are ready to go now...
Hp30, cryod spicer 4.56's, lockrite, drilled rotors, 297 shafts, new unit bearings, new passenger side balljoints, knuckles drilled for heims, setup for 3link coilovers with upper on passenger side.
$400.00obo.
15x8 black steel wheels, 3.75bs 5 on 4.5 pattern, rs diy beadlocks, quick air down valves, extra ring and hardware.
$200.00
Ruff country 1.5 wheel spacers, set of 4.
$80.00
Rings are black now but still no rock rash, run true and dont leak any air..
Would you consider welding stock coil buckets, LCA mounts, and shock mounts , double shear or studs back on? :greensmok
I don't want the Truetrac as I live in snow country. Do you have the carrier that you took out to put in the locker? 3.73 or higher.
If I am going to put this in my Cherokee it needs to be very straight forward. :confused1
I also can wait for you until after the first of the year no worries.
Just asking because I don't weld and I'm not much of a mechanic. :repair:
$400.00obo.
$200.00
$80.00
Steering and trackbar also included with front axle. $400.00 firm
If needed i can put coil buckets back on if buyer supplies brackets. Ballistic fab has them available.
There are no stock brackets on the 30. All brackets are from ruffstuff except the tracbar bracket. I can put coil buckets back on it but you will have to go to a 3-link setup. All the brackets are setup the same on this new axle im building as on the 30.
you wouldnt happen to be going to HH on the 29th? interested in the beadlocks
No, wont be able to make that run... if someone from up this way is going we can see if they will haul them down..
that would be sweet. ibdont know anyone up that way though
im taking the beadlocks
