XJLI
- Long Island, NY
dont invest in a 16.5" rim. its stupid. get a set of non beadlocks and tires off of pirate for cheap.. plenty of stuff up there now. lots of 38-42" stuff, but idk if you want to go that large.
60 day warranty is up on motor. :lecture:
There is a guy in RI that can give you some pointers on running 38" tires
Nothing is stopping you from starting without beadlocks and adding them later.
I'd go for a 17" rim.
with a 60/14 i'd rock 37s minimum. 38.5s are a cool size for lots of fun and awesome tires. you doing a strech at all?
why 35s? plan on getting some for really cheaps?
I only said 17s for tire options.
If you found a good deal on tires for 16s I'd have no problem getting 16s.
yea I guess your right.
the wheels that came with my 60 dont have alot of backspacing. but they dont look stock. Idk Im just going to have to do some more reading and maybe check out some Junk yards.
i found some 37x14.5 creepys for 417$ but there for a 16in wheel. I know colin said I should look for 17s any reason 16 wont work. i think theyd clear my breaks. and if not i could do some caliper grinding.
16" steelies with like 4ish" BS will clear the calipers no problem on a ford 60, but if you wanted to run say a 16" wheel off a newish chevy/gmc like the HD wheels for example, I'd guess that you'd have some issues.
trevor has 4 38.5x14.5x16 creepys. i dont think he plan on using them.
Fo realz
And whos trevor?
Hey chedman, I'll buy those two Mud Country tires off you if you don't use them.
