Hampton Roads M&G
Came by your place today Jared, nobody was home, around 2ish. Went to home depot and got some wire and clips and after fiddling around with some home made jumpers I came to the conclusion the bad spot is a cut wire upstream between the plug and fuse box. I clipped in wire splicers between the left and right sides, and all lights came on... HOWEVER... So does the front turn signals... getting very tired of this...
i was in suffolk having a friend attempt to weld my exhaust leaks. its better but im still leaking.... getting very tired of this x2. im going to be kinda busy this week and out of town this weekend so i dunno if i can help ya soon.
its cool. Ill figure it out. I think If I find the hot wire on the passenger side and tap that to the other two on the passenger side. Or replace from the fuse box...
With Doc Holiday back we need a M&G. Doc, which stand down you taking?
I am taking second leave period, M&G sounds good to me, I didnt join up on here until during deployment trying to troubleshoot the jeep, so I dont really know anyone.
Il n'est pas de problem-- glad you guys made it home safely!! what the hell are you doing up @ 05:00????
Its a combination of excited to be home and I have been sleeping 11 hrs a day the last couple days to make the time go by quicker.
Well Doc, we usually meet up at shorty's, so when you free? We usually do friday or saturday. Hows your duty schedule look?
Anybody protest friday? Shorty you going to be at the store or should we actually go somewhere? maybe show off the unity of jeepers
i wont protest, nor will i be there. got a family thing up in michigan.
Store sounds good, I was planning on going to Ruby Tuesdays and then crashing on the boat that night anyways.
^^^^^^^^very true
So Jared, got a closer look at that plug under the passenger side we was looking at, there was a rock that has rubbed more than a few bare spots in a few wires. I cut the BLACK?YELLOW cause it was the worse, should not have done that, now I have to re-tap it. should I just go find a entire new box, the property has asked about it now, I can't let it sit around much longer with out a sticker...
the white and black; black yellow; and solid black I have found thus far. I'm posting this up in OEM too. see if I can figure out whats going on...
if you say so-- new avatar to match!!
how'd the exhaust shop go?
still a small leak but goes away when everything heats up. exhaust sounds pretty good. got a nice growl to her now.
as of now I plan on bringing my red jeep to the meet friday. I am going to go to that donor jeep jared posted a link to and see what goes into replacing this entire harness. If its not too much work Ill just do that, at the meet... OR! the rear brakes, Ill buy a spring kit now that I have money...
So shortys about 6?
