Would these mess with my rear pinion angle at all?My 1.5 in lift shackles are sitting at about 80 degrees this direction(\), with the OME HD rear leafs.If I add this kit and get the angle back to about 45 degrees on the shackle, will that change my rear pinion angle?I ask becuase everthing is dialed in now.
Briano13- Just wanted to say thank you for an awesome product. I ran in my first endurance race in tuscon az called Dirt Riot and after one hour off racing i finished 6 laps and came in first. The rear shackles with your kit allow so much flexs thanks.
If your intreasted i credited your prodcut in my you tube videp here.
Mother of God. You know when Cal starts endorsing something it's gotta be good
KOH build looks outstanding, I've been following closely.
BTW Brian just out of curiosity, is this your top selling product? If so by what percentage is it beating out your other stuff. Seems like these are selling like crack.
Brian any plans for new products in the near future? I know of some products that are desired but not produced by anyone (or have been discontinued). Seeing the quality work on my shackle brackets I wouldn't hesitate to buy anything else from you.
mine gave me 5/8" with the stock shackle, so there is 5/8" built into the new bracket assembly minimum. With extended shackles, just take 1/2 the additional length over stock (i believe the stock ones are 3" hole to hole) and add it. You want a 45 degree angle with the weight on the tires (ride height).
Lift from brackets = 5/8" + (shackle length over stock)/2
