- Lafayette, CA
Not to nitpick, but you can legally sell an 80% lower, as long as you are not doing it in mass. One or two shouldnt be an issue, but Id hate to go many more than that and have the ATF decide you are a manufacture and not a private citizen. Not sure why you would sell more than one 80% lower anyway, or why you would even sell any lowers at all! If you sell it, you would have to get it serialized, but you call legally sell or even SBR your 80%.They are typically referred to as "80% lowers". So long as you finish the machining yourself (even if that finish is pushing the start button), they are legal. Quality varies significantly though. They will even do build parties where a shop will setup their CNC for the day to just run the 80% lowers. However the ATF doesn't take kindly to them because they typically will have the same company doing the machining that sells the 80% lowers and it gets just a little too easy.
EDIT: Technically according to the law, any gun that you build yourself is legal for possession but not sale. The 80% complete state is where companies have found the ATF to not give them significant hassle on so they stay there. And yes, any lower that was built from an 80% state cannot legally be sold or given to anyone else, ever.
I would suggest Fred simply buy a cheap stripped lower from a local dealer. Name does not matter much since you are going to be building a Frankengun anyway, the roll mark will not matter for resale purposes. As long as you buy a good mil spec lower, go for it.
80%s are cool, but factoring in additional requirements of machining, they can become more expensive than a normal stripped lower.
Remember to factor in tax if you go local, and shipping/FFL fees if you buy online.
Not sure what the laws are in WY, but CO requires government issued ID with a CO address, so even though you own property in WY, if your license has CO listed, thats where you should get your lower.
