Got crack?
YELLAHEEP
Finally got around to parting out this '89 2dr I've had sitting around for a long time. Never really looked at it too closely since the outside of it was so beat....... man, talk about a cracked unibody. This was the kid's daily driver until he got deployed...... :eek:
Door about to fall off - torn hinge mounts.
I've NEVER seen this many cracks in the door sills/striker mounts......
Cracks above each "B" pillar.
"C" pillar...... I never was able to open the hatch, jammed shut with a cracked striker mount wedged up in the works I suppose.
When the tilt column quits working and flops around...... Booger weld it! Unfortunately, no one told him you can't weld cast aluminum with a stick welder...... I had to hold the wheel just right to keep the ignition switch engaged...... :D
Not to pick on the poor guy...... but this was his trail rig....... Hopefully he's working in a Fleet Maintenance unit of the Army and will learn a few things.
my 92's front doors are cracked just like that, around the ports to the inside of the door
must be brittle steel, it should stretch more than that. That was scary!
Sweet ride...
i'd buy that for a dollar. :D Just watched RoboCop for the first time in years.
This looks like something I saw in a VD video years ago!
Wow! Looks like that one had a fuuuuuuuuuuuull life! LOL
mtnhigh said:
It doesn't look to me like there was much left to part!!
Surprisingly, the engine/5 speed were in pretty good shape - ran very nice. So yeah, I harvested the engine/trans/t-case and a few odds/ends but that's about it.
