Jeff 98XJ WI
- Butternut, WI
Ok, you are looking at full stuff with both sides equal. What about with the axle articulated. I think you may have hitting if the pass side is stuffed only because of the width of the frame. It could be tuned with bump stops.
You've got a point there. The coilovers will be mounted just inside the steering knuckle probably on the inner C's, so when the axle is articulated the steering arm shouldn't raise very much. However, I can see how that could be a problem especially with the drag link. I can trim more of the bottom of the frame, but it could get into the balancer. I guess we'll see. I really wanted to keep full stuff at or less than 8" from the frame. I plan to set the coilovers to be fully collapsed at the height shown in the above pictures. This will allow 6" of up travel at 7" of lift. In any case, I'm going to work on the crossmember and control arms now. I'll make them fit at this amount of compression then see how things look as I cycle the axle up and down and twisted either way. Jeff
