I spent all weekend trying different things and mostly just staring and googling different ideas. Anybody have any information on swapping the king pin steering knuckles side for side? I was thinking of putting the stock steering arm pointing back on the passengers side so I could mount an assist ram to it similar to what Goatman has done. I would then run steering similar to what he is using. One drag link from a pitman arm to the top of the inner hole on the ballistic arms and then a tie rod from the bottom of the drivers side arm to a tab welded to the drag link over by the passengers side knuckle. I think I could run that and have it clear everything at full stuff...barely. As for the ram, I would rather it work on a side to side tie rod so it is pushing one side and pulling the other but I don't know if I can make that work with the steering links setup like Goatmans. I really didn't want a ram pushing on the back of a double ended high steer arm and trying to pivot it on the studs in the top of the knuckle as I think that is just asking for breakeage plus I already have a single ended arm. So, I thought if the ram were pushing/pulling directly on the stock steering arm portion of the knuckle, that might better withstand the force. The only issue I see is that I would have to run the brakes on the front portion of the rotor, but is that a problem? Anybody else familiar with swapping the knuckles side for side? Also, I think I'll have to use a flat pitman arm and found out that an Astro van has just the ticket, so I'm shopping for one of them now.
Just for your information, here is some data I took. I mocked up a straight tie rod from high steer arm to high steer arm and then measured side to side movement of the steering holes letting the knuckles swing from steering stop to steering stop. I got 7" for the inner hole and 9" for the outer hole in the Ballistic Fab arms. I then measured the throw of the WJ pitman arm from lock to lock on the WJ steering box and got 7.75" with the WJ arm being 6 1/8" center to center. A Waggy pitman arm produced 8.5" of throw with it being 6.75" center to center. The Ballistic arms measure out to 6 5/16" for the inner hole and 8.5" for the outer hole from the king pin center. You can see that the Waggy arm will not produce enough throw to operate the high steer arm from stop to stop when in the outer hole! Jeff
