splitz said:No it was definately 6 quarts...one 5 quart jug + one 1 quart bottle.
dzraces said:is your oil pan dented?
Billfaceeee said:After running the motor you've got to wait at min 5 min's before checking the dipstick, even then pull it out and whipe it down about 3 times, on the third time look at the back side of the dip stick it will show the amount.
splitz said:I'm probably the worst auto hypocondrack you guys have ever seen. I get nervous about almost any noise I hear from the engine, which really sucks, cuz from what I've read there is considerable valve noise in the 4.0...kinda reminds me of a sewing machine.
With a Jeep, just put in the 6 quarts and you're good. What you're saying is definately a must for semi-trucks though because the oil filters need to fill up(usually takes a little over a gallon of oil) and then engine needs to be topped back off to the full mark on the dipstick.60thAnivrsryXJ said:Ok I would like to know how many people think this is a good idea. You change your oil and then you refill it until the dipstick reads full then run the engine for about a minute and then check the dipstick again and add more oil until it reads full again.
All Jeep 4.0's hold 6 quarts of oil. What do you mean they only hold 5? Are you draining 5 out and only putting 5 back in?JohnX said:Just read through this thread...6 qts??????
Both of my cherokees only ever held five. One was a 94 and one is a 97. Both 4.0's. What gives? BTW before you tell me I'm checking it wrong, I'm not.
