Hello!
Newbie Swedish XJ owner looking for help!
Been working on my Cherokee XJ 4L, 97 in order to get it running again after it's been sitting for two years. Changed oil+filter, airfilter, sparkplugs, serpentine belt and broken oil preassure sensor. Except for overheating/fan issues the car was running ok before it was parked until now.
So. After putting in the new parts and charging up the battery the car started perfect like it had had just been driven.
Turned off the ignition few minutes later to check for possible leaks. But when trying to start it again it just cranks. After trying about five times, going out and back in the car, i notice a burnt smell and smoke coming from the middle of overhead console. Rush to get a fire extinguisher but luckily nothing caught fire.
Partially removed the conole and see the following melted connectors:
Also notice accumulation of moist/water droplets inside the console. My guess is this is what somehow caused a short and the following burn?
My question is simply how to best fix this issue? My alternatives so far is to buy a full console (preferably second-hand) or just the "security keyless entry module/board" and replace melted connector from wirning.
As I'm basically a complete newbie with jeeps and these types of problems and have no idea if this will solve the problem by itself, or perhpas cause a secondary conflict/problem with the main computer?
Not sure if this might help, but since I will mostly use the XJ on backroads and during winter near my own property I have no real need to lock the car.
A bit lost so I apreciate any help or guidance regarding this issue.
/JE
/JE
