Fuel pump will not prime
Well there's only 3 things on the list so until you've checked them ALL...............
If you have 30 and 87 jumpered and you do not have +12 volts (to a known good ground), then the wire has failed!!!!!!!!!!!!!
30 is fed directly from a fuse in the PDC
Main fuse block (PDC) not a PCM!
I had a similar issue, yes, i know this is an older thread, anyway, after pullin my hair out chasing ghosts, my new pump (that was soundin good) wasn't pumping! Thanks again china parts. Fortunately it came w/ a lifetime warranty. Now to deal w/ that stoopid rubber isolator that stayed in the hole when I removed the pump AGAIN! The first time I ended pullin the tank dammit...
