Mdob2000xj
Hey All, I’ve read quite a bit on these forums but never posted. I’m looking for help as I’m lost on this No Bus issue. It all started when I was doing my heater core. I took the dash out completely, unhooked all the wires and removed it from the vehicle. After I finished the job I put it all back, and had 0 no bus related issues. When I charged the AC system, I realized I had a blend door stuck open. I pulled the dash again, this time without disconnecting wires or removing it from the vehicle. I was able to fix the blend door and put the dash back.
When I reinstalled the dash and cranked it up I had the dreadful no bus code. My symptoms included erratic gauges, door locks operating overhead lights, rear wiper always on, rear defrost light always illuminated. Also CEL is on as well as the airbag light.
I’ve driven it a few days with this issue and the symptoms have slightly altered. I’ve noticed my horn doesn’t work, except when I hit the lock button and it goes off! The passenger door actuator will sporadically go off and hold, even started smoking while I was troubleshooting.
One thing I noticed that seemed strange, the wire that runs to the ignition switch felt hot, specifically on the section where it has a metal cylindrical piece.
In my attempts to fix this, I’ve removed the instrument cluster and cleaned the connections and reinstalled. Looked for broken/pinched wires. Removed, cleaned, and added dielectric grease to engine bay grounds. I also checked the module located under the glove box which was tightly secured.
I’m at a complete loss and don’t know where to go from here, especially with smoking components. Any advice would be greatly appreciated!
