- Northwest Ohio
today it was in open till the coolent hit 100 deg, so i guess i didnt see it the first time
Yeah, it usually sits at 0 but every now and then it'll hop around. I think there's someone else here on the board that has the same issue.XJ01-08 said:BBeach, when i have one of the guages set on TPS mine jumps like 16 or more when im idleing and it jumps like 10 or more when im driving, does yours do this too?
Thats what mines does. So there's no way to manually adjust our idle is there? :dunno:XJ01-08 said:Only problem is mine doesnt do it every now and then it does it like every 5-15 second or is that about what yours does
"The last dyno run I did was performing after I flashed the PCM Adaptive Memory while on the dynamometer. We then ran the test again, using in essence the Base Setting that come in the PCM from the factory. This resulted in a loss of 9 HP and 17 ft/lbs of torque."XJ01-08 said:Good i thought my TPS was going crazy and the FSM says that you should not attempt to change the idle with the screw on the throttle body(whoops lol) and Idle is controlled by the PCM so i guess their is no way to adjust it, maybe you could try and clear the adaptive memory here a link to the directions http://www.mhjcontherocks.com/Community/TechWriteUps/196.aspx
BBeach said:Just curious what you guys thought of this. I get about 22-23mpg average on the highway when going 60-65mph. However, I lost O/D on my last trip home, and not having much time since i had an interview i just kept driving at 2500rpm at 60mph. The reason I did this, was the scangauge was telling me I was getting almost the same fuel economy. Now this is something I was thinking of for a while, is the your fuel efficiency is dependent on your load, how much force you need versus how much you provide, etc etc. So I figured that with the additional thrust from the lower gear (3rd), that despite the increase in rpms (within reason...this didn't work past 3k or so) it helped balance out the drag on my jeep decently.
Some stats I found interesting other than the increase in mpgs. The load seemed to be a little lower than the usual, the TPS was less, as with the MAP and my ignition timing jumped from 35btdc ot 45btdc. At first I thought the jump was because the engine was spinning faster, less time for the fuel to mix, etc etc but when I'm doing 75-80 when I had 4th gear, it was ~36-38 or so. I guess as a rule of thumb, if you have more ignition advance (lots of variables to this statement), that you are going to have better vehicle efficiency. Take it or leave it, but one of these days I'll do a "load required" vs vehicle speed graph and see how I could match my gearing/tires to optimize mpgs (at least highway).
Any opinions or input?
Theres more to it than that i'd think. But there would be more vacuum due to the throttle being opened less. At the same time wouldnt that mean there would be less of a mass of air going in than we would think? As in, I know the rpm is 25% or more higher, but it also has less pressure so thatd be how it wouldnt be such a large drop in mileage. But the whole point of what im trying to say, is that the timing is advanced and itd be more efficient despite the higher rpms. I think its just a huge force balance kind of thing and we just need to match our force output as best we can.srimes said:More vacuum = more advance
