2000bluexj
- Mass
Anybody ever do thisto an xj? Had the idea to get a better approach angle. Would prob only be like 2-3 inches Trim body and maybe some tube in the front. Jut wanted to see if anybody has done it
x2.RCP Phx said:The bigger issue will be what to do about steering.
where wuld i find more info about these? mayb i will just tube the front end a little and leave the wheelbas where it isIXNAYXJ said:x2.
What are you doing now where you're compromised by approach angle? With the right bumper and long arms, Cherokees have a pretty amazing approach angle. Check into the Moab4x4 Outpost bumper; probably the best out there.
-----Matt-----
2000bluexj said:where wuld i find more info about these?
thanks i found it. looks nice. i have been looking at the protofab rock solid and the tnt customs front bumpers as welljoshv98xj said:
You have any picures of the build or of the front suspension?ktm racer 419 said:my front end is stretched about 2". it's pretty mandatory to clear 37" tires without intruding your leg room.
i do rub the front of the inner fender a little, but its a nice smooth surface and hasn't hindered my steering noticably when a tire is stuffed.
steering still works, trackbar mount was moved back slightly along with the coil buckets to make the coils sit like stock.
2000bluexj said:You have any picures of the build or of the front suspension?
