Inisadow said:found a stainless steel set on ebay probably getting them if i dont get out bid in 4 days.
No problem man. A lot of the after market sets do not include items 5 (as Kejtar said) and 28, although both of those are really easy to make yourself, so I wouldn't let that get you down.Inisadow said:Thanks for the blown out picture of the towhook brackets that shows a lot more detail than I have seen any where else. Looks way stronger and I would have to do little modification to adapt them to my setup right now. One question how does the rear most bolt/nut(34/33) attach to the frame? I see no holes to mount it on my jeep, except one possibly, does it go all the way through and get tightened down? How much will I have to drill to mount them? I didn't think they came with the angle iron piece to strengthen the front mounting point or the cross brace piece.
I use a nylon strap for towing.
GSequoia said:Please let us know what after market bumpers you refer to so that we can steer clear of them. Using those three bolts is just absurd! A proper bumper has longer arms that tie into more "frame" points, somebody here can provide pictures I'm sure.
Kejtar said:If that's a set I have seen before, you will have to fab yourself item #5 as it's not included with the set.
88woody said:What is the purpose of Part #5? What about #28
