alex22
- CT: waterbury area
That's not quite true.BlackSport96 said:The only flaw is that it was a track bar that failed which doesn't affect which way the wheels go, it locates the axle under the vehicle. Basically the track bar goes and now the axle can go whichever way but the wheels will still be controlled by the steering wheel and tie rod etc.![]()
well, I stand corrected...ChiXJeff said:That's not quite true.
The tierod will definitely affect steering. If the entire axle shifts, the endpoint of the tierod stays in the same place (assuming the steering wheel isn't moved.) For example, if the axle shifts to the left, that'll pull the balljoints left, while the tierod stays fixed, and the wheels get pushed to the right.
I never said you had control...........Ramsey said:You still have some steering but you can go full lock and it wont actually turn very much. Fortunately mine happened on a trail. (broke bolt)
Ray H said:Just a meaningless little question that I dont think anyone has asked yet.
Do we actually know that the TRE broke and caused the accident, or did it break during the accident?
Did anyone check the other steering and suspension parts to see if one of them may have failed, causing the accident?
Im wondering if he was making a right or left turn when he lost steering. It would almost have to be a right turn to PULL the TE apart. A left turn would mean the TB would be under a compression load, not a tension load. In addition, the right side suspension would be compressed in a left hand turn so the TB wouldnt be over flexed at the time.
Never said you did? You have very little, some, but not enough.ChiXJeff said:I never said you had control...........
Ramsey said:With safety washers if you go the heim route.
WheelinJR said:TRE's in trackbars = bad.
I encourage everyone to convert to a double shear lateral mount of some sort instead of the vertical single shear factory design. Something like the RE bracket and bar, and if you're not going to do that, at LEAST run a heim setup like RE's 1600 trackbar
djblade311 said:even the Rusty's HD double sheer end didnt work to well for me:
and that was only a month old.
Way too much thread hanging out on that.djblade311 said:even the Rusty's HD double sheer end didnt work to well for me:
Ramsey said:Way too much thread hanging out on that.
im runnin the Rk setup with a hiem, what are safty washers and what are there purpose?Ramsey said:With safety washers if you go the heim route.
rk setup is double shear, and thanks on the tech on the safty wahser, i didnt know about themRamsey said:Is it in single or double shear? In double its not needed, in single it will keep it from separating completely, if the center of the heim pops out, the safety washer will keep it from falling all the way off.
Nope the main problem there is the threaded section is too thin for the application.Ramsey said:Way too much thread hanging out on that.
